D 17 Series 2
boilerpete View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerpete Quote  Post ReplyReply Direct Link To This Post Topic: D 17 Series 2
    Posted: 16 May 2018 at 5:43am
Under the clutch housing, there is the clutch inspection plate.  Forward from that, at the bottom, there is an additional 1" hole.  I'm dripping oil out of that constantly.  Where's it coming from?  Only thing I can think is that the main seal is leaking.  But the oil is a darker brown than what's in the sump- I just changed oil, so its new.  The stuff that's dripping is old.
TIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 7:00am
Leak from the front end of the torque tube maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 7:05am
There is always clutch dust in that housing so oil runs through it turned it dark. While it is split, replace rear main and torque tube shaft seal. MACK
This page was generated in 0.116 seconds.
