Which Bush Hog for WD45?
Craig(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig(IN) Quote  Post ReplyReply Direct Link To This Post Topic: Which Bush Hog for WD45?
    Posted: 11 Jul 2010 at 11:31pm
I think I would like to find a pull type woods bush hog for my WD45. Does anyone know which model I should be looking at? I think the PTO HP is 38 on the WD45.  Thanks in Advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 5:12pm
If I was buying one, it would be 5 or 6 feet wide. It also would have to "stump-jumper" disc under it to protect the fragile WD45 PTO driveline and possibly a shear pin on the PTO shaft on the mower.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 6:39pm
I'm with you Dr Allis! I run a 6' pull type Bush Hog brand mower with a "stump-jumper"
And have the slip clutch set to give before the PTO gear box gives up.
Don
