CA plowing
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Topic: CA plowing
    Posted: 15 May 2018 at 6:09pm
I finally got to plow with the CA. I was plowing in second gear about 8"s deep. It worked really well.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 6:24pm
I sold the CA and plow I used to plow with for fun on this 8 acre patch I live on. Good little plowing tractors.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 9:52pm
I always LOVED to plow with the CA.  Neat unit.
Good Luck!
Bill Long
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 1:28pm
do you have to use side engine weights with that, or is it good to go without weights?
1947 C, 1949 B, 195? CA
60 series cultivator
fertilizer side dresser
2 bottom snap coupler plow
1 bottom plow, Cole planter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 3:09pm
Plows great without weights its all in the traction booster setting. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 6:24am
What’s that coming from under the left tire??? 😳 it has been raining here for 4 days and forecasted to rain well into next week. We may not see conditions fit to plow until June or July.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 6:35am
We are getting real dry all most all of the rain has been south of us. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 8:52am
Dad never had weights on the Ca except one C inner wheel weight he would put on the landside wheel. I remember seeing him going up a small clay hill at the "other place" with the front wheels off the ground, but in normal conditions, the fluid filled 13-24's did everything he needed.
 He even plowed some flat cornstalk ground at half throttle in 3rd gear many times. Handy tractor to have back in the days of 15 to 20 acres fields with fences all around.
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 12:14pm
I don't see any of those Rocks of Gibraltar that are so prevalent in your part of the state!  You must have a crew of good rock pickers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 8:32pm
Been married to my rock picker for all most 46 years. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 9:09pm
Here are some of the rocks Wisconsin evidently didn't need. They came down here under a glacier  many years ago. This one has been called the haystack rock for as long as I can remember. This bottom ground, just a half mile from the Mississippi is the only place around that I know of that has any rocks near the surface.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 9:31pm
Randy,
Very nice work with the CA! Good to turn some dirt! Did you get the plows shined up good?
