Gas can replacement nozzle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: Gas can replacement nozzle
    Posted: 13 May 2018 at 9:31pm
Was in the local farm and home store today looking for a large funnel. Hate my gas can EPA approved nozzle and was just going to pour straight out of the can into the funnel and speed things up. Asked the young man working what I was after and he pointed up and said " why don't you buy one of these replacement nozzles with a vent hole you can install ? ". Well you learn something new every day. Bought a couple and could not believe how well they work
Edited by Pat the Plumber CIL - 13 May 2018 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 9:46pm
you gots a pick of one? my newest nozzle comes out at a 90 degree turn, and you hafta push a button for the vent. with the type container i'm using, it works o-k.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 10:02pm
Ask and you will receive
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 10:06pm
hey! just like the old style! wonder how long it'll take before someone out there messes it up? you better buy several, for when the kids or neighbors stea...uh...borrow it! think i'll look locally for one! thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 10:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 10:09pm
There were 2 different models. This is the wider fast flowing model and they are not kidding. Bought the smaller one and it flows pretty fast as well. Little pricey 10 bucks apiece
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 10:14pm
I quit using the big red containers for mower gas, seems they always disappeared after I filled them, I now use the blue container for diesel, and the yellow one for kerosene. I still have both them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 5:08am
Been buyin chilton gas cans, fer years, now, at estate auctions.  I just buy all the old gas cans, ant take the nozzles off, leave the cans and gas, lessn the can is real pretty and new... Bet I have 25 replacement nozzles, now...Wink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 5:51am
I found out you can just take the core out of a valve stem, drill a hole in the gas can and install the valve. The screw on cap from the stem keeps it from leaking.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:37am
Shamers, you just gotta fill a gas container 3/4 full water an put in a few cups gas for stink an leave it a little ways from the road alongside the driveway....
  Had a jug with a collapsible yellow nozzel like the black one above, it became brittle and broke at every ring and the jug became brittle too and cracked and leaked. Plastic don't last either... Thumbs Down had a metal can that had a rubber nozzel and that lasted for years until rust got the bottom of the can.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:52am
I got some replacements just like that from tractor supply. They do work!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 11:39am
Diddo
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 2:05pm
I'm gonna go check out TSC,,,see if they are better than my homemade one,,,,
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 3:26pm
Got one of those exact sets for filling the WD, you better be ready them things will empty a 5 gallon can in about 10 seconds. Came with an extension piece also to make it about 2 feet long which is good, you can bend it in the filler neck before tipping can really helps cut down on spilling.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 6:12pm
I've got a couple of those too with the extension, only had to fish the extension out of one tank so far.  I bought several Jerry cans at estate sales and auctions, painted one yellow that had diesel in it.  But these new spouts sure make quick work of fueling up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 7:31pm
Thanks for the info, Pat. I need to visit TSC and see if I can find some. I hate those EPA approved ones. Of course we don't have Ms Big Ones at our TSC like some lucky fella does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 8:04pm
Dave, Chilton is one of the cans that these nozzles fit.  Sure wish you would have save the cans. Cry
They have them at Rural King for only $7.99.  That's the cheapest I've been able to find them.  It's hard finding the older cans/plastic gas containers.
I haven't tried myself, but they say they WILL NOT FIT the new type with that STUPID push down spout.  WHAT kinda junk are we being stuck with?!?!
Just cause some dip chip can't figure out hot to NOT get gas all over hisself...
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 7:12am
Hmmmmm, wonder what else Diy is hoarding, maybe all the .22 ammo?  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 10:00am
Yep, if I can find an old can, I will save it. The new cans I have use different threads...I guess they got smart and figured out what we were doing...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 2:04pm
I find all them fancy epa stupid chit 'no spill' spouts are more gas wasteful than all the old spouts put together were... except for a steel flex hose on an old army can...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 5:56pm
Yes, I hoard chilton and sears (same) gas can nozzles.  Around here they don't sell the replacement nozzle kits, has to do with what area of the country you live in, and EPA rules.
I started this hoarding, long afore it became fashionable, seldom pay more than a dollar a spout...
Uster could get the kit fer $4.99, @ tractor supply.
Gubmint thinks the new spouts that spill half the gas, and then another hour, fer the rest to get into what you are pouring it into, will hep the environment, LOL!Wink
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 11:01am
I live in a place with more of them Fruits and Nuts so had the pain in the axx gas cans 30 years or more.Use to always have a gas can in the pickup for the pain in the axx Cat pony motors on all my tractors,that no vent worked good to keep the can from tipping and leaking. Until with no venting the daxx no good can started swelling up and split.Angry
So like before we CHEAPWink folks us what we got for FREE,all the plastic gallon and 5 gallon oil jugs and bucket. But now the trouble Confusedis keeping a funnel clean and handy.
Edited by Ray54 - 16 May 2018 at 11:06am
This page was generated in 0.539 seconds.
