engine problem
Ed&Sherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Topic: engine problem
    Posted: 13 May 2018 at 9:38am
wrong color  ,,,JD8400,,plowing ,engine bangs and stoped,,,,last night pulled the valve cover and found one broken rocker arm, one bent push rod,,but the rockers are all real loose to the point you can remove all of the rods by hand,,the rocker arm ass. is tight and not broke....what happened??? broke cam gear?could the cam slide forward?  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 11:13am
I know they can slide, if the cam is busted...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 12:50pm
If the engine is locked up?  ... you'll figure it out when you tear it apart.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 1:39pm
You may want to check the 8400's transmission for a fault which it's 8.1L engine may have absorbed the transmission's stopping forces??
https://www.redpowermagazine.com/forums/topic/7759-a-john-deere-that-ate-itself-for-lunch/?page=2
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 9:48pm
I would say cam shaft is broke for some reason. Most common reason is when it throws a rod, it usually gets the cam.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed&Sherry Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 9:59am
broke cam,1 lobe off crank,,1 sleeve bottom broke , crack in block other wise good to goCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 8:40pm
My neighbor bought a slightly used JD8110 a few years back. Didn't get 200 hours out of it and the engine puked. Scoured piston on one cylinder. He did a little internet checking, and found it was a common problem on that engine, but JD never fessed up to the problem.
 They told him some ridicules price to put one piston and sleeve in, but couldn't guarantee the others would hold up. I think it was 14K to get it back in working order with new sleeves and pistons.
 I have run it a lot, and it's pretty handy for light tillage work, but lacks higher field speeds , just can't figure why JD would let that engine go with known problems in them.
Edited by CTuckerNWIL - 20 May 2018 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 9:40am
It's like GM's oil burning and their ultra low tension piston rings. Same with Ford on the 6.7 Diesel. The valves and stems are too thin to survive long term heavy usage. Their other problem is they didn't put a downstream injector in the exhaust to regen the DPF like GM did. The oil gets fuel contaminated and they spin bearings.
