200 hydraulics
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulics
    Posted: 11 May 2018 at 10:44pm
Was discing tonight and all of sudden the disc wouldn't raise and power steering wouldn't work..is there a spool like the 190 pumps that have to cleaned or any ideas....going to drain all fluids and change filter in morning to see if that doesn't help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 10:49pm
I'm gonna guess you are very low on hydraulic oil. Take at least 5 gallons with you and figure out where it went. CHECK THE TRANSMISSION FOR BEING OVERFULL !!!
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:29pm
Splines wore out on my XT pump and it quit going down the road. Did the same as yours, no hydraulics at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 12:20pm
Just changed fluid and filter for hydraulics. Still no steering and nor do the lift arms lift..any suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 2:12pm
I tore into the pump and I'm working on getting the plunger out but I keep finding little bitty pieces of blue rubber what could that be.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2018 at 3:14pm
The section seals and the seals under the wear plates are a blue Teflon material. Sounds like a complete rebuild is in order. I guess it could also be blue silicone from some previous work??
Edited by Lynn Marshall - 12 May 2018 at 3:16pm
