Unstyled WC Brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC Brakes
    Posted: 11 Jul 2010 at 8:42pm
Does anybody know if the brake pads that Steiner Tractor Parts sells for a WD or WD45 will fit on an unstyled WC? If not do you know where I would be able to get some pads at?
Thanks, Jeremy
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:36pm
No they will not. Check with Tony @ tony's tractor, I know he has the bands. Yours arenot shoe brakes
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:45pm
Thanks for the information, I am somewhat new at this and will probably need alot of help in the future.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:10pm
Welcome to the Forum! Ask all the questions you have - there are lots of people on here who can - and will - help you.
WC, CA, D14, WD45
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:44pm
If you are wanting to do the work yourself you can buy the blank brake material and rivits from McMaster and Carr.  I can send you the part numbers if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 11:01pm
Could you please post the part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 9:06pm
The part number from McMaster-Carr are;
Brake Lining    6175K138   (4ft will be more than enough)
Brass Rivit       97451A671
