Air Cond. problems in my truck
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: Air Cond. problems in my truck
    Posted: 06 May 2018 at 8:15pm
05 Silverado 3500, ran the a/c last weekend and worked just fine, today not so much.  Compressor won't kick on, system has plenty of pressure, fuses good, if I manually make the relay contacts the compressor runs.  I have 12v to the relay coil but not a ground.  I have swapped relays with a known working one and nothing.  I have manually jumpered the low and high pressure switch individually but nothing.  I noticed a check engine light, diagnostic said low voltage circuit B, cleared the fault, nothing.  Is there another pressure switch besides the one on the accumulator tank and on the discharge line?
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 10:06pm
Have you put a code reader on the truck?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 7:31pm
That's how I got "I noticed a check engine light, diagnostic said low voltage circuit B, cleared the fault, nothing."
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 7:39pm
Wendell, I don't claim to know anything about that truck... but on many FORDS there is power to the switch / blower / fan etc... and the dash knob when rotated completes the GROUND CIRCUIT..... Many times people are looking for the switch to supply POWER to a component, when actually it forms the GROUND..........  bad switch or ground wire ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 8:36pm
Yeah, that's kinda where I'm at, after rechecking the pressure switches with a test light they don't have voltage so I'm just guessing that they are on the ground circuit since I have 12 volts to the relay coil.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 7:55am
Is the blower working?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 8:05am
Yes, blower works, snowflake appears when I turn it on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 8:10am
It has a trinary switch on the high side. You need to look at the data for the system. Sounds like you have a malfunction like the 5v ref side down or shorted to ground and the ECM is withholding compressor operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 8:37pm
Well I went out tonight armed with a wiring diagram and a meter, started the truck and the A/C worked just fine.  I never moved it or anything since the last episode.  Now I know it aint like a sore thumb and just up and healed itself but I am going to be prepared.  Only sure way I know to make it happen again is. . . . Hey Maddux, want to go on a road trip?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 9:05am
We used to roll down the windows for the AC!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 11:54am
lol....I was in town the other day and stopped at the gas station, a dude asked me why I had my windows rolled up on such a hot day? told him so the ac cool won't get out! he said (with a funny look on his face) that old truck has a working ac???? told him..yeah don't yers? (he had a pretty new truck) he said his quit the year before and figgered it was done. said he might see if he can gits it fixed. yeah Les and Joe...it was a newer ferd pickup!
