Found a BARGAIN!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Found a BARGAIN!!
    Posted: 06 May 2018 at 4:37pm
Ran across this on STL CL.
1985 GMC 7000, 366 on Propane with an automatic, as it sits runs and drives $500.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 5:09pm
You selling?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 5:24pm
DANG........ got twice that just in tires !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 5:54pm
I will be resurrecting the Brother In Law/his son our nephew's dump truck with this one!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 7:07pm
Check the frame for cracks.  A propane guy once told me that they quit running propane engines because they vibrated so much it would crack the frame welds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 7:39pm
engine should be clean inside with it on propane! nice looking truck anyways!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 8:18pm
That is a bargain! Good clean truck. And Shameless will be proud you bought a Chebby.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 8:35am
I think I would be verifying the Serial Number Title through local Police and also Carfax before I bragged too much.
That may be more than just a 'steal'
EG this 1985 GMC is priced a little bit higher !   $8,000
Gary
https://columbiamo.craigslist.org/cto/d/1985-gmc-2500-rc-lb-price/6577406208.html
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 9:54pm
John I ran one of those for 3 years. It did not vibrate until I lost the brakes one day. Was headed back to the shop downshifting to slow down. I was starting to turn in the drive at the shop, downshifted and broke the crank just ahead of the flywheel. It still moved but it did shake bad. Oil never got dirty, I used synthict oil in it. Should make a good truck for you.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 10:19pm
Gary
2 totally different birds. The one for $8000 is a pickup, he bought an actual truck. And just because they're asking $8000 don't mean it's worth that much, or they will get it.
I bought my 1986 C70 2 years ago for $1000. Around here the going rate for TRUCK like that is $2500-6000 depending on condition a what bed is on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 10:32pm
I have a C60 that has no brakes, but I drive it anyway! bought it for $1500 when it still had brakes! is a gasser, bit runs good! 18 ft box and hoist on it.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 6:32am
Great deal. I had a 79 Chevy 7000 with a 366 and Allison automatic. It also had a 2 speed axle and air brakes. In its final years here I installed a 450 bu gravity bin. Two speed axle is great because in low it has gobs of torque for field work but will run out of RPM's at about 40 mph.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 4:37pm
keeping the propane or converting to gas ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 11:57am
Keeping the LP. Have the other beast on gas where have to drain the crappy stuff available EVERY time it has to sit long. Goes south and sour as if designed to at around 30 days.
LP can get a different set of tanks like a fork truck, mount a hanger and fill as needed where if shut off will not sour.
