AQC WD Oil Filter Tube?
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Topic: AQC WD Oil Filter Tube?
    Posted: 05 May 2018 at 7:45pm
Is there anyone else who has the tube for inserting into a WD oil filter? AGCO wants $47.00 CAD for this little item....surely there are cheaper versions of this item?CryCry
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:50pm
Its just a tube, it can be made from scratch, from copper or steel tubing, as long as it fits into the filter base, and doesn't dent the top of the filter, when the filter is tightened.  Also, Wisconsin engines also used this filter, so you might find one on a V2 or V4 Wisconsin engine...
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 9:07pm
Check Steiners Parts
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 6:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 7:21am
Like Dave said they can be made. I used a piece of steel brake line, I put a screw in the top and a small hole below the screw for flow.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 5:40pm
Rod (NH)  has the dimensions and info here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 5:41pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2018 at 6:57pm
Piece of 1/4" brake line tubing from NAPA, $1.59 per foot
This page was generated in 0.678 seconds.
