WC parts
Dean (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (NC) Quote  Post ReplyReply Direct Link To This Post Topic: WC parts
    Posted: 11 Jul 2010 at 7:19am
From a visual inspection, the 1940 WC seems to need rear axle seals and front wheel bearing seals...Have not had anything apart yet...just noticed leakage.
Where do you find the typical small parts?  Can you pull the seals and just go to a parts house and compare them or is there any specialty shops?
Dean
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 7:22am
Go to the top of the page and click on PARTS.
Sandy lake can get or has most of the stuff you want/need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 7:28am
The rear hub seals won't be found at your local bearing store. I believe the front had felt seals which I don't think are available anymore. A rubber lip seal for he front can probably be found at a local supplier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 3:05pm
thanks guys.
