diesel dodge runs again
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: diesel dodge runs again
    Posted: 03 May 2018 at 2:35pm
OK, SSON put contaminated diesel in his pride and joy a MONTH ago, FINALLY got it back today. Bill for the insurance company was just under 10, 000 Canucks !! Dealer replaced everything ,except tank. so filters and  injector pump, $10,000 !!! tht doesn't include krappy rentail PU with NO hitch. I'd love to see the bill AND I'd want ALL the used parts too.
So much for saving 3 cents per litre ( 12 cents per gallon ) of diesel. AND he writes it all off anyway....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 3:05pm
What year truck ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 4:22pm
2015 I think, well pretty sure, more or less....
I'm betting the dealer only puts a 30 days warranty on parts too !
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 6:53pm
I've been seeing ALOT of signs posted at fuel/gas stations around here advertising they DO NOT have bio/soy diesel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:14am
seems the 'fuel' looked like mtn dew.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 4:33pm
It's not the soy based that's a problem. The problem is if you never drain the water trap and water gets past it to the pump and injectors, OR you screw up and pour DEF in the fuel tank and run the engine. If you ever make that mistake NEVER NEVER NEVER NEVER NEVER turn the key on or start the engine. If the DEF is only in the tank, it's a simple drop the tank and clean it out. Water dispersant products are one of the worst things you can do to your fuel system. This includes all alcohol based products like HEET or Sea Foam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 9:19am
Jay...which diesel was in that Dodge? guess it don't matter...was just wondering
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 9:57am
a '15 would be a 6.7 in the 3/4 ton or the 3.0 VM Motorri in the 1/2 ton.
Edited by Brian Jasper co. Ia - 05 May 2018 at 9:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 11:13am
some 3L POS they dumped into a 1/2ton 4WD 8' box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:49pm
sounds like the eco diesel...it's 3. something
