D15 diesel series 2 high crop
17evansga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 17evansga Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel series 2 high crop
    Posted: 02 May 2018 at 10:35pm
We’re there any factory d15 series 2 diesel high crops made. If so what r they worth?
TIA
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 5:24am
There were no true A-C D-15 high crops.  There may be Thompson conversions out there.
The A-C version is a 'High Clearance' which will have 38" rear wheels and are usually single front wheel. Some also have rear axle extensions to make the wheel track wider. Value is what you have to pay but more than a standard D-15 of the same condition.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 3:44pm
While in south LA I saw quite a few equipped with 13.6-38 and axle extensions. There was a high front axle spindle and most had 16" tires.  When equipped with cane cultivators there were chains attached to the snap couplers to lift the cultivators.   Paul Ed was the dealer at Abbeville Tractor   - Simplicity here on the forum  was the #1 son - still had it last I checked.
