Forgotten Machines and Companies
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Forgotten Machines and Companies
    Posted: 01 May 2018 at 10:55am
https://contractormag.co.nz/classic-machines/tractomotive-wheel-loaders/
  A article on Tractomotive loaders and AC is on page as well as other history
Forgotten companies: Tractomotive
Classic machines: The scrapers of Curtiss-Wright
Edited by Coke-in-MN - 01 May 2018 at 10:56am
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 1:28pm
What a great looking machine. Lose her lines. Would have so much fun with that on my property. thank yo for sharing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 1:29pm
LOVE HER LINES. CRAPPY SPELL CHECK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 4:51pm
Explore the site as there is a lot of machines and lot of history on that site .
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 2:13am
articles are by 'wabcoman' aka richard cambell ; new zealand. Is good articles in there on HD5 6 11 16.  Even a bit in the HD11 article about a old fart i know quite well with a 11ep Wink
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 5:45am
That 'Old Farts' name wouldn't start with Merv would it!!
Edited by DMiller - 02 May 2018 at 5:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 12:13pm
your a clever fella Dave Wink
seriously articles are good though. HD6 one really good
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 4:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 8:35pm
This popped up on another site. Definite AC, slightly modified. The story is clearing brush with the drum on a cable on severely steep hillsides. It did not end well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 1:22am
Dunno what you read Dave but that machine was certainly going 2 years ago. Machine is a HD16DP, massivly modified by its owner; a real AC guru, certainly the nz HD11 guru. He had several 11EP and series B tractors, all bush rigged, over the years. He built this in the late 70s. He sold this and the 11ep about 2 years ago. Has 21000 engine. Power is there to drive the custom made winch drums which used the steering system from a valentine tank to clutch and brake the independent winchs ; which control the 11000 kg roller so you can steer it down gullys. to flatten scrub for forestry conversion. Absolutely unreal to watch in operation; have seen the roller actually climb ten feet up a pine tree before smashing in in half and continue rolling.
Original owner and builder is still going, and has a mint Allis 'HD5.5' he calls it that because has GM 3-71 power, HD6E track frames, 4 spool hyds and tows a cat 40 scoop.
cheers MervBeer
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 1:28am
Was a number of these machines built in NZ for gravity scrub rolling. At least 3 others were built on Terex 82-30 and 82-40 machines and another on a HD21A with the drums on a turntable running rearward. The terexs were the same design as this but built by other owners and people
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 7:09am
Awesome, I believe they said that roller got loose just after photo was taken. Sorry for the mix up.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 8:16am
was this to make the mountains usable for range land?  obviously you couldn't farm it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 12:15pm
Hi Dave; ropes breaking is something that happens; and can be quite calamatous when one gets away ! Alot of wasted time pushing roads into gullys to attach a rope or series of ropes to retreive roller. He used to run 5 ton rollers off the winch ropes on the HD11s for crushing smaller easier blocks of land.
Alot of the land had be used for sheep farming Cal; but when prices dropped out of sheep in the 70s alot of land reverted to scrub quickly. At that time the govt was paying a subsidy to plant pine trees; pinus radiata, or monterey pine being the favored species. When Lex first built his roller he came down to my area to work for govt forest service to scrub roll some marginal land for 3 months. It worked so well, he was there for 4 years !
This page was generated in 0.174 seconds.
