exhaust aspirator
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: exhaust aspirator
    Posted: 30 Apr 2018 at 4:08pm
Would like to eliminate the muffler on my steiger and go straight pipe but I need an aspirator. Has anyone ever made there own that works like it should? I can buy a kit from shoup for $400 some odd dollars but all I need is the aspirator. I've seen people just weld a small pipe inside the middle of a stack but does that alone create enough vacuum to function?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 5:38pm
Found this, on the combine forum...
We put a muffler on our r62 from harvest salvage in Brandon MB, its off a case tractor and i can tell you this, that venturi almost sucks your hand in. If you want one with it in the stack. check combine salvages. the Gleaners all have straight pipes directly from the turbo. there is a venturi there in the pipe. it has a curved stack and everything about 3 feet long.
best of luck.
Lee (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 5:54pm
In the past (15 years back) Donaldson offered a few straight pipes set up for this, I do not have a catalog handy, but was a pipe with a venturie formed into it with the tube through the center.
Lee
B212
912
Willy's Jeeps
Gleaner K
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:18pm
I believe still do.
https://www.donaldson.com/content/dam/donaldson/engine-hydraulics-bulk/catalogs/Exhaust/North-America/F110028-ENG/Exhaust-Product-Guide.pdf
Page 49 in the catalog.
That's it!, I used the "Expanded end Style", they worked very well.
Lee
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:53pm
The picture shows it on top of the muffler,will it work at the bottom of the stack? The one on my gleaner says right on it "not to add any more pipe on top of it" must effect performance.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:24pm
What is an exhaust aspirator, how does it work, and what does it do?
Other than that, I am quite familiar with them.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 7:32pm
Simply put, it uses the flowing exhaust, to create a vacuum that agitates or purges debris, from an air cleaner...Wink
