200 brake questions
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 brake questions
    Posted: 29 Apr 2018 at 7:06pm
Right side wasn't working. Took it apart and disc material was gone on both discs. I didn't take the actuators apart but how often do the balls fail or flat spot? I am getting my info together to order the discs and didn't know if I should go ahead and replace the balls and springs or not? The left side is either on or off no in between. I slide the tire every time. Do you think there is a problem on that side or is it because the right side would not work?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 8:05pm
IT would not hurt to check the balls for flat spots.  If found, you might as well replace them while you are in there.  If the wheel locks up when you hit the brake, it is definitely time to replace them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 8:51pm
Balls should be ok, but clean the ramps where the balls work.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:18am
ALWAYS REPLACE SPRINGS WITH NEW !!  Lightly grease or anti-seize the ball pockets after cleaning them. Do the same anti-seize on the outer machined contact surfaces where they are supported when installed inside the brake housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 11:34pm
Thanks for the replies I have ordered the discs and will order the springs and balls in the morning.
