I 60/ I 600
donm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donm Quote  Post ReplyReply Direct Link To This Post Topic: I 60/ I 600
    Posted: 10 Jul 2010 at 6:47pm
  I am working on a AC TLB.  No ID tags to be found.  It is a D 15 Diesel chassis with a Loader and mounted Backhoe. May be a I 60 or I 600.   Believe it is factory.  Boom swing is cylinder with linkage, not a rotary cylinder.  I am in need of a dipper stick cylinder, or the dimensions- bore, stroke, rod size and end pin sizes, so as to try to find a replacement.  Any help appreciated.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 9:19pm
If it has swing cylinders, it's likely a 615. Is it two stick or four stick control?
615's are the last with the D-15 power train, except the diesel was the newer 2200 series.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 7:53am
Could be a D15 Industrial
