Suggestions before I fire the ole Gal Up again
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Topic: Suggestions before I fire the ole Gal Up again
    Posted: 28 Apr 2018 at 8:04pm
So it ran a few years ago. But I had some trouble getting it to turn over without alot of effort and it ran at really high rpms it seemed. A small radiator leak was also there. Then Some water got in the head sitting outside and it seized up.
Now everything is unseized, new valves, seats, new radiator, starter and generator were rebuilt, new wiring harness, rebuilt carb, different magneto, all new lubricants, tie rods, gaskets, hoses etc.
I just have to bolt the head back on and put the push rods in.
Anything else I should check or have done before I attempt at starting it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 8:19pm
What model is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 8:34pm
What model is it?
Sorry I forgot to mention it is a late model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 5:14am
Only thing I would add is to keep an eye on oil pressure, when she starts. leave the VC off, and make sure the upper end is getting oil, and make sure governor is functioning and getting oil, too.
This page was generated in 0.123 seconds.
