Lawn Tractor for the Wife
BrainOOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainOOnt Quote  Post ReplyReply Direct Link To This Post Topic: Lawn Tractor for the Wife
    Posted: 28 Apr 2018 at 3:35pm
I am getting a lot of hours on My Allis 416H.Still does not use any oil unless I work it hard Snow Blowing.Need a 42 to 44 inch Hydro for Brenda to Mow the level ground to help out.Cant find anything local used worth bring home.Looking at Cub Cadets and Huskvarna.Don't want to spend the summer fixing lawn mowers as I have two 1953 Aliis WDs trying to make one out of 2.Hand clutch is out of My Loader Tractor.Got a low hour reversed WD fork Lift .The rear end gears have been reversed.Big Project.I should sure use some advise.Thanks Brian PS.When I get the Wd done will Have a very good front pumpe fore sale with all Hydralics Its Hydralic Steer
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 7:07pm
Contact Ross D. a Forum Member, I believe he has some nice Allis Garden Tractors For Sale.
Gary
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 7:11pm
well, Brian... my personal opinion on this subject was formed over fifteen years ago...
Prior to what I use now, I split the grass-grooming process between an IH Cub Cadet hydrostat tractor... either a 109 (10hp Kohler single) with 44" deck, or a 782 (17hp Kohler twin), and a Lawn Boy 2-stroke to hand mow between the trees, around the areas that were cumbersome to get with the tractors.  I had just under an acre of riverfront lot, plenty of trees.
One day, I was gifted a Dixon 308... a 30" 8hp cone-clutch drive zero-turn, and even with smaller deck, much less power, it would mow the yard in under a quarter of the time, and use less gas.  I eventually wore out the original 8hp, called around for a replacement, lo and behold, Dixon offered me best deal on a replacement engine... just under $300 got me a bolt-on direct fit.  Opened the box, it was 17.5hp Briggs Intek OHV, used less fuel, had more power, and half the noise, started like a champ, and I loved it.  Wife didn't like the fact that it was blue, and didn't have a steering wheel, so she wouldn't touch it, but I only needed 40 minutes to mow the whole yard, so I didn't care.
When I moved up here, my yard volume increased considerably, and while the 308 was just as happy... even with overgrown grass, that 17 slashed right through like it wasn't there. a larger deck was certainly in order, though.  Ann helped out by using the Cub Cadets to mow the large open areas, I did around the trees, edges, and tight confines.
She happened on a fellow teacher-friend who summertimed as a small mowing contractor, he had one machine that'd easily survived it's depreciation, but threw a rod (Kawasaki 21hp) and had three flat tires, been sitting for a few years, but 60" deck... asked if we wanted it, I said ##ll Yes!, brought it home, applied a 27hp Kohler, four tires, three spindles, and two hydraulic dampers, two belts and an idler, and added 3500hours to the operating clock since then.
Now, she wouldn't run the Dixon, and swore never to touch the Bobcat, but came out yammerin' at me one day on account of an upcoming outdoor reception at our place, I was mowing as fast as I could, if she wanted it done faster, she'd hafta hop on and take over... lots of cussing and hydraulic noises ensued, and while I fired up the Dixon and started going round the edges, she banged and carried on a few passes... by the third pass she was cutting passes WFO as a brunette Weapon of Grass Destruction, as fast as I could trim the edges, she'd clear the opens.  Nowdays, she STEALS the machine from me, and mows it ALL, with no worries.  Puts on noise-reduction headgear with FM radio, and clears our 5 acres in less than 2 hours.
Go back to a tractor?  Never.
Commercial zero-turn, or ROUNDUP.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 7:49pm
Hi Dave!
I had a Dixon 422 cone drive since 1981 being as the assistant plant manager lived 2 doors down from me where they were made in Coffeyville, KS.
That thing paid for itself time and again and provided me a decent income for a single guy at the time.
I also got really great at keeping the cups adjusted into the cones and other normal maintenance as I used it heavily.
I actually wore out the cups as they couldn't made to fit into the new cones and a new transaxle was in order. Got it and kept on mowin'!
Edited by Jim Hancock - 28 Apr 2018 at 7:49pm
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 1:39pm
we were in the market for a new or newer mower, the old lady.....ooops...I mean the loving wife was like Kemps....didn't want no part of a ZT mower. I went ahead and bought a used grasshopper anyways. she %#&%^#@* me, but then finally got on it and played in the yard. next thing I knew she was looking for more places to mow! PffffT! we sold that one, really only thing wrong with it was it had a black seat like most do anymore, but it sat right above the engine, and it would cook yer butt! when looking for a new/newer one, came across a new Dixon ZTR with the kowasucki engine and a 54 inch deck. bought it, and we almost have a race to see who can mow with it next! I usually win since I can gits on it while she's at work! had it 3 years now, no problems yet (hope that didn't just jinx me). i'd buy another one just like it if I had to. they even have grease zerks on the spindles and other places that others expect you to buy at a fast pace when they wear out!
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 11:04pm
Enjoyed DaveKamp's options:      Commercial zero-turn, or Roundup.     Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 10:33am
Bought a Bad Boy ZT Commercial used a few years ago. Never looked back! Took two hours off my mowing time from the 3' finish mower that I used for years.  We have 3 1/2 acres and 3 of it is lawn. That 27HP Kohler rock n' rolls man. 60" cut and get outta' the way! Even Jo Jo likes it cause' its fast.   LOL!   Thumbs Up
Steve@B&B
