liquid nitrogen
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: liquid nitrogen
    Posted: 27 Apr 2018 at 6:54pm
when putting it on by sprayer how well do the streamers work?? i have some need advise
and i see a guy on youtube just spray it on no streamers
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 7:00pm
Liquid nitrogen?   At 320 degrees below zero?
Or do you mean NH3?   (Anhydrous Ammonia)
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 7:11pm
28%, right? We apply that by regular sprayer. It can also be injected, but you are probably talking about puttin it on wheat. You dont want over 40 pounds of N per acre cause it will burn it, and could streak it some.
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 8:52pm
If you are going to put 28 on Wheat dilute it with water if it does burn it some it will come out of it.
This page was generated in 0.184 seconds.
