2 year old seed corn
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: 2 year old seed corn
    Posted: 25 Apr 2018 at 8:21pm
i have about 15 bags of DeKalb seed corn that's 2 years old, do you think it would still be ok to plant ? its been in the dry.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 8:26pm
I planted some I had given to me for food plots for 5 years. The 4th year, I thought my 1890's JD planter messed up and skipped a few. Last year I finished out that  seed in my "new" planter, no tilling into standing beans. Only about half of it grew.
 I got something different this year Wink
Orange Glow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Glow Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 8:32pm
Most of it will grow, if it was stored properly. We did a test plot with some of our new brand of corn (Becks) and some of the older Mycogen that was left from a couple years before. It yielded competitively, so it really didn’t bother it much to be older. We usually buy several pounds extra of sweet corn seed and put it in the freezer for years to come.
Edited by Orange Glow - 25 Apr 2018 at 8:34pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 8:42pm
Plant it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:14pm
This was stored in the shed on a concrete floor and no moisture got to it, but it was subject to temp. change ie. hot and cold.
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 10:31pm
Do a germ check. Get the wife's cake pan, put a inch of dirt or potting soil in it and plant 100 seeds. Keep in an area that will stay above 70* then count how many come up. Better yet plant some in her house plants, she'll keep em watered for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 11:56pm
yep...what Tom and Lee says!
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 6:30am
It doesn’t matter that you kept in the dry. Some times it will germ and sometimes not. I just threw away 3 bags that was that old only a few grains per sample would germ. Do as Lee says
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 6:43am
Seed company I worked for back in the 90's would do germination tests on small grains. Lay out a couple paper towels. Place a row of seeds across center of towels, fold towels in half over seeds. Get towels wet and let sit a few days. You can open towels up to check on progress of germination.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 7:29am
I also do the paper towel test and use the wife's cookie sheet.  She used to scream more when I used dirt. Stern Smile
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 8:40am
Only way to know is to do the germination test.  15 bags....so we're talking a "farming operation" not just food plots or whatever.  You could up the rate some if the germ test shows lower germination.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 9:07am
From what I've heard on the price of seed now, by the seed not pound anymore, I would definitely test it and/or plant it.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 10:52am
Most of you would be shocked at the TRUE age of the seed you plant!
ALL COMPANIES do germ tests, submit the results to the various states,,,,,,,,,, and that resulting date becomes the date on the end of the bag.
But heck,,,,,,,, if it germs out at 96-7%,, what does it matter? Less than 90% usually become salvage corn and is burnt in power plants,,,,,,,,,,, or roasted, and the coating burnt off to feed to hogs. (This depends on the seed coat of course!)
Of course placing seed in a "salvage" class is resisted a lot!
Soybeans are a different breed of pups because they don't retain the germination factor like corn!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 10:57am
And yes, John,,,,,,,,, corn seed has been sold by the 80,000 kernel unit for several years now,,,,,,,,,,,, not by the pound weight. If you check your bags,,,,, I'd bet it describes the unit as 80,ooo seeds, with a bag weight of ####.# pounds.(I've seen this vary between 37 and 48 pounds a lot.........................
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 9:38pm
I farmed two very pieces of land and always used some old seed to fill out the planter instead of buying another bag.   Could never tell the difference always yielded good
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 2:15am
mix it in with your new seed, it'll cross pollinate with the other plants. I've put last of a bag seed in with new seed before, never hurt my yield any!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 6:48am
OK...
WHO counts them when they buy them !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Glow Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2018 at 7:09am
There was a couple people who actually did count a bag of corn! According to our seed person, it took them all night, and it was right about 80,000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 9:17am
OK...
Been sold that way for decades I'd say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 9:20am
How old?  The year prior.....? Me too.  2 years?  How old was it to begin with (as dipstick points out)?  Point is, a germination test is super easy to do, extremely inexpensive in the scheme of growing corn, and the only way you will really know.  A screw up in poor germination could easily cost $1000's on the scale this guy is asking about.
This page was generated in 0.138 seconds.
