B and CA same block?
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: B and CA same block?
    Posted: 24 Apr 2018 at 12:47pm
Are the blocks for a B and a CA the same? Just different size pistons and liners? Heads, crank, rods the same?
Thanks in advance.
Edited by littlemarv - 24 Apr 2018 at 12:52pm
The mechanic always wins.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 1:13pm
The B (from 1947), C and CA have the same bore and stroke, so I imagine the block is the same as well.  The C and CA have higher governed engine speeds than the B.
Edited by HoughMade - 24 Apr 2018 at 1:19pm
1951 B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 1:26pm
Without a parts book I can't be sure. In the shop manual
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
The engine for the B is listed as model BE with a different bore than the engine for the C listed as model CE, but probably the same stroke. BE bore 3-1/4" CE bore 3-3/8". Compression ratio for BE 4.92:1 CE 5.25:1.
The specs for the CA engine match the CE engine version in all listed details. In the CA tractor section on crankshaft seals the engine serial numbers begin with CE and its noted that the seal was changed a couple times in the production run and the timing cover was changed once along with the seal.
It might be that http://grandpas-tractor-site.s3.amazonaws.com/manuals/ac
has parts books for the three tractors so the parts could be compared.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 1:54pm
The B had the "BE" engine (116 ci) from 1938 until the change to the "CE" in 1947.  After that, it had the "CE" engine the same (basic) engine as the C and CA.  There were definitely different governor springs in the C and CA to allow for higher RPM (the CA even higher than the C).  The "CE" engine had a "low octane" version with the 4.75:1 compression ratio, but standard compression for the B, C and CA was 5.75:1 for all.  The "BE" engine had lower compression than the "CE", but was never used when the C and CA were manufactured.
In other words, it looks like the block, sleeves and pistons for a B after 1947 with the "CE" engine, the C and the CA are all the same.
Edited by HoughMade - 24 Apr 2018 at 2:01pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 2:43pm
If you compare the latest B engine to the CA engine, tractor data says the CA was higher compression??
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 2:53pm
I see that, but I am going off the manual.  Granted, perhaps the manual I am looking at was published at a time before a bump up in the CA compression.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 3:52pm
A very old "B" will not have the mounting bosses for a generator bracket cast into the block. So, you could always use a newer CA block on an old B, but not an old B block into a C or CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 4:26pm
By mounting bosses, do you mean the two threaded holes on the left front of the block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:19pm
 Yes, I have seen a lot of BE blocks that were drilled and taped so a generator could be mounted. They just didn't have the boss and the block is thinner there without it.
 CE sleeves and piston can go in a BE block or visa versa if you wanted.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:22pm
Is that when the bore was increased, with the CE engines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 8:50pm
Yea, they just put in a bigger piston  with a larger bore in the sleeve.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 8:58pm
Put c a carb on my 49 B and had to file holes to get it to go on .Old carb fit but venture was gone .Engine surges some when not under load.I think there is some difference in a B and a C A . May be in intake or head.Venture seems to be to big but i can live with it.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 11:03pm
One slight detail is the CA crank has a divet in each of the rod journal. The crank also has a different casting number
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 7:30am
The 125 engine actually was first introduced as the R engine in the RC.Then became the CE engine when the model C was introduced in 1940.  I have RC #686, with engine #R692.
Also I think the rod bearings on the CA are lubricated through the crankshaft, which is why there is a number change for the crankshaft on the CA.  The connecting rod number should also be different for the CA, and should not have the little hole along the beam of the rod that was used to oil the rod bearings on the Bs and Cs. But I don't know about this for sure.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:15am
I do not remember the piston measurements but the pistons on the CA came even with the top of the block and the older pistons were down a tad which would chance the compression. they were down even further for the dual fuel tractors all in the 3 3/8" diameter pistons. The only difference in the block was a cast in non machined area that looked as though it was for a possible fuel pump. As far as the head the only difference I found was in the ports below the valves which was in the internal casting cores. This would have nothing to do with horse power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 10:48am
My B cranks good .When pullng real hard and low on gas it will cut off but crank right back up.I think venture is big and pulling hard vacuum drops and will not pull fuel in .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 11:12am
I found an oversized venture will help with higher RPS's but will cause less lugging power when getting larger than needed. It is kind of a balancing thing with what has been done to up the HP.
