Allis 8070 rear hydraulic remote leaking oring?
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 8070 rear hydraulic remote leaking oring?
    Posted: 23 Apr 2018 at 11:38pm
Hi our 8070 on the top remote where the hydraulic hoses contact leaks bad. With a hose plugged in oil just runs out. My question is there are orings that would need to be replaced I'm assuming? How hard is that to do and step by step how to fix thanks so much.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:07am
Take a small screw driver or pick and peel the old one out, put a new one in.  15 cents and 30 seconds and you'll know if that was the leak or not!LOL  Likely is, it happens.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 11:54am
If it’s later style, junk them and put on 7000 series style.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 4:48pm
Can you buy the earlier style couplers new still. I have the later style on the 8050 and 70 and they are always leaking.
Also. How hard is it to change out the detent end caps on the valves. The main remote on the 50 won’t hold in raise any more and if I tighten down the screw it wont pop out of detent when I lower the disk.
Sorry to hijack the thread
