185 3pt cylinders
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 185 3pt cylinders
    Posted: 23 Apr 2018 at 9:36pm
I have one that started leaking bad, it has the large dia piston/rod. I have one with a small dia rod sitting here, can I mix and match??
ALLIS EXPRESS!
This year:
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 6:11am
I can't speak as to whether or not mix and matching is a good idea or not, but I can say that with two very in-expensive seals (actually, one seal and a wiper) from Agco, you can have your leaky cylinder fixed in pretty short order. Darrel
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 6:58am
I did mine, super easy, snap ring lets go through the oil line with a small screwdriver
Edited by whatscooking - 24 Apr 2018 at 7:01am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:52am
good advice - they will interchange , but the large cylinder with 70253347 and wiper 70253346 and 15 minutes  - you have to remove the cyl anyway, will cure the issue for a long time...
