R-50 combine over head console switch
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: R-50 combine over head console switch
    Posted: 23 Apr 2018 at 12:43pm
At the bottom of the tattletale 3 monitor there is a pic of a combine with what looks like the chopper or the cylinder is "highlighted" with a high-low rocker switch directly below it. The op book doesn't say much about it or what that switch controls. Would some one tell this old dummy what it does. Thanks Dave
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 1:07pm
You switch it to high when you have the chopper drive belt on the high speed pulley and set it to low when on the low speed pulley...if my memory has that correct...
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 2:10pm
Like Amos said, it's so the tattletale reads correctly. For instance, if it's set on "high" but you're running the low-speed pulley, the lower speed will trigger the light on the monitor when in reality, everything is working fine.
