CA hot manifold?
Brian/Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian/Pa Quote  Post ReplyReply Direct Link To This Post Topic: CA hot manifold?
    Posted: 23 Apr 2018 at 5:04am
went to work on Dads CA last night and the manifold at the carb flange was hotter than hell, my C's and B don't get this way. sprayed some carb cleaner around to see if it was sucking air but is wasn't.   I don't recall manifold getting that hot before. anyone have an idea what might be the issue?    thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 6:03am
really lean mixture or advanced timing ?
I have to ask , does it perform( work) like it used to ?
Jay
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 6:54am
I would check the timing first thing and then probably let her rip.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 6:57am
Heat conduction maybe?
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 7:54am
Retarded timing will make exhaust hot.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 8:22am
As wbecker says. Needs some more timing advance. Retarded timing will make the exhaust manifold cherry red if you are working it hard. Not sure where you time the CA but someone will tell yu. On the WD45 there is inspection window underneath at clutch and marks on flywheel.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 9:02am
Timing should be covored in the op manual which i don't have. It might be found at:
http://grandpas-tractor-site.s3.amazonaws.com/manuals/ac
How it works should be covered in the shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 9:32am
If you static time it use the "DC" mark on the flywheel as seen through the hole on the left side of the torque tube.
If you have a timing light, adjust it while running to the "FIRE" mark on the fly wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian/Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 5:09pm
timing is dead nuts, I just noticed that it gets hot. runs great, but I will check mixture after I get the final drive back on.   replacing bull gear seal is a major pain in the butt.
thanks again
This page was generated in 0.058 seconds.
