B rear wheels??
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: B rear wheels??
    Posted: 22 Apr 2018 at 1:24pm
My b has the famous loose rear wheel. I put up with it all last year looking for 5lug rears ans adjustable front, but im not paying as much for a front end and rear hubs as i should be able to get a tractor for.
    So iv draged one of my parts tractor out of the bushes. And trying to get the big nut off the center of the wheel and im about to give up! Iv tried heating, air chisel, soaking with penetrating oil, even my old stand by melting wax down into the threads with no luck. Im about ready to cut it off. I was just wondering if any one had any tricks?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 1:28pm
I have never had the occasion to work on those.
Are they R/H and L/H thread depending on which axle ?
Gary
The Consultator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 1:31pm
What's the famous loose rear wheel? Mine has a slight 'hop' to it that I can't figure out.
1939 Allis-Chalmers "B" restored in 2010- very good condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 1:58pm
Im not sure about the threads but judging by what threads i can see i think it just regular threads.
What happens is the cast wheel center get worn-out and wont tighten up anymore
It cause it to clunk and wobble back and forth a little.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 2:33pm
Use a 4 1/4" angle grinder with a cut off wheel. Take a slice of the nut as close as you can to the threads without cutting the threads, might need to do that on 2 opposite sides of the nut. then a big chisel and hammer.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 2:42pm
Try heat and impact wrench
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 3:14pm
cut an split the nut on one side it will come off' make sure your turning it the right way'also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 3:24pm
That what im think im going to have to do. Is there anyplace you can get new ones thought?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 4:20pm
I still can't find a wrench to use on that oddly shaped axle nut. What wrench are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 4:47pm
Iv got a factory wrench for that, but iv been useing a big adjustable wrench and a big pipe wrench.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 4:51pm
Can't remember exactly how it comes apart but if its that tight I'd try to pull the whole stub shaft out as the one with the worn hub probably has a worn axle too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 6:55pm
Kamerer makes a bunch of quality parts. They have an axle nut wrench for B & IB, I think they may have the nut too.
http://stores.ebay.com/KAMMERER-INC?_trksid=p2047675.l2563
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:16pm
Take a cold chisel and make a heavy cut on each side and that will streach nut and you can remove and reuse . Dad used to do that on square nuts  when parts were scarse and tools were few.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:52pm
Thanks lots of good stuff, and he got the nut and a lock washer for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 9:42pm
Is there a good place to get the seals and bearings needs to replace the axel shaft on while im into this? Mite as well do it all while I'm at it.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 10:08pm
If you have a spare final drive you can find the same nut holding the bull gear in place that holds the wheel to the axle on the outside. Both have right hand threads. I have taken some off with a 4 foot pipe wrench with a 3 foot pipe on the end. I have also cut some off. Never had one come off easy.
Edited by Dick L - 22 Apr 2018 at 10:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 8:17am
Dick is right, there is a nice new looking nut inside the final drive if you have a downer final.
DJS I think has the cones, bearings and seal. You can also get them at any bearing supply such as https://www.motionindustries.com/
The axle seal is 415001 you can read the numbers on the cones and bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 9:36am
Thanks that will save about 50 bucks on that nut
