D17 diesel camshaft
chuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel camshaft
    Posted: 21 Apr 2018 at 6:59pm
Have a early d17 diesel and wondering if the camshaft is the same as a WD 45 diesel looked in the agco parts book and shows they have same part number I got some from both tractors but the numbers on the camshafts do not match?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:11pm
The 262 cam has flat places for rods to clear cam. 230 can be ground to work.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 11:40pm
The can that came out of the 45 diesel has the flat spots between lobe's if that's what your talk about, so it must of been updated or changed at one time. So it should work then right. Putting the two side by side I can't tell a difference. Thanks mack
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:48am
Should be ok.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 8:10am
Thanks mack, just curious looking in agco books, the d19 diesel also has the same part number as d17/wd45, so they would all use the same camshaft, maybe some gear changes on the latter d19.
