Model C front post
10-E Chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10-E Chalmers Quote  Post ReplyReply Direct Link To This Post Topic: Model C front post
    Posted: 21 Apr 2018 at 1:50pm
Hello everyone! I just rescued a great 1941 C from a fellow that didn't seem to believe in basic maintenance, the biggest issue I have on my plate is the front post where the steering gears mesh, I took the front off and when I took the bolt holding the gear out I noticed that the shims were missing and that the gear actually sat about 1/16" below the bolt, could I remove the gear and put a shim below it to bring it up so it would mesh properly? Is there any place to buy anything like this or would I be able to Fab something? Thanks!
Grease is always cheaper than bearings!!!!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 4:26pm
I have shimmed that gear but ever 1/16". You will have to make what ever shim or shims you use. Any that I shimmed under the gear would get tight turning right or left and still have some play at the center. I just worked to a happy medium.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10-E Chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 8:31pm
There must be a point where it must have worn I'm thinking, it would be great if a person could find the original specs (blueprints) and find out where it is worn, then build it up from there.... Once you do one then you could rebuild a few more, wouldn't make much money from it, but it would help a few folks out there..... I'll try to shim it first I guess!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 9:41pm
What's the serial # on yours?  I have a 41 with # 3308.  Mine was an EARLY 41.
Hope you get it fixed!!  There are a LOT of C's out there and you could just swap out the front end.  I could steer you toward a couple of guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10-E Chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:12pm
The serial # on this one is C3960, and I may have a replacement for this one, but I was hoping not to cannibalize from another tractor.... I guess that I'll have to invent another fix, unless someone else can find a better answer, shimming still sounds like the best option at this point
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 6:25am
One of the reasons I am broke and have 400 non completed projects at 80 years is because I always want to re make things before buying parts. When it works it gives a person great pleasure. When it doesn't work the third or forth try you learn not to try to fix it that way the fifth or sixth time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 10-E Chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:40am
