6080 not mine but neat
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 not mine but neat
    Posted: 19 Apr 2018 at 1:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:00pm
Very nice!!!!!!!!! Whats the story on this one
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:12pm
I like the look, very cool. But why would you want to do that?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:45pm
Been atleast 3 threads with that tractor on here before. Besides why bastardize a perfectly nice tractor.
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 6:23am
Why not do that. I think it looks pretty good. If you are bored and want something different. Better than another modified B or WD picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:37am
Sorry but I think it's darn sharp looking and without a full story I am not putting it down there were a lot of red and green factory tricycles made and they do have there place
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:57am
Other than backing stuff in a barn where are the advantages?
Let’s see the disadvantages
Less stable
Another set of tracks to run more crops over
Can’t straddle a windrow of hay or straw
Worse in mud
IHCfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:59am
How did he do that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 9:23am
There most usefull place is not around you obviously and on that note I am done
Edited by bradley6874 - 20 Apr 2018 at 9:24am
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 5:12pm
If you are raking hay with a side delivery rake or mowing hay with a haybine the narrow front is great for sharp turns and making square corners when mowing hay. Power steering is also a big plus. I grew up on narrow front AC's. At one point dad had WD45,D-14,D-17,CA all narrow front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:32pm
Here folks cut hay like they plant corn. Few laps around plus some “end rows” and then cut lengthwise. If it’s a wide field I’ll split it. Square corners just adds stress to the U-joints.
The front wheels running on the windrow just shatters leaves and stems. First tractor I drove was a NF C never thought man that was handy. I had chances to buy the C after his passing and refused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 10:45pm
OK Victoryallis I think we all know by now that you HATE narrow front tractors so you can STOP bashing them. I'm just saying back in the 1960-70's(before disc mowers) if you cut hay in "lands" as you describe there would be lots of wasted time driving across the ends. I've mowed many,many fields with haybine cutting square corners. In other words the machine was always mowing hay and header never raised till the strip thru the middle was finished and NEVER EVER replaced a u-joint. Times change and now some guys mow as you do and that's fine. As my father always said--Every farmer has his own way to do things but the end result is ALWAYS the SAME.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 11:14pm
Lots of uses for NF tractors really good in the woods,when disking won't leave a track on the outside like a WF when making a turn.Plus they look pretty cool.Have several NF tractors I use all the time.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 11:15pm
There were a lot more IH H's and M's with narrow front then wide.  And look at all the JD B's and A's.  Great for cultivating, pulling a grain drill.  IMHO, I think the 60 series looks great with a narrow front.  May be the only one in existence!
Allis Express participant
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 6:11am
So 90 degree corners stress U-joints but 180 doesn't?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 6:44am
I always thought that was the reason for u-joints. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 6:55am
If they are so great why did manufacturers stop making them over 40 years ago?   Correct me if I’m wrong conversation kits were also made to go WF.
First tractor I drove was a narrow front C and drove a narrow Minne Mo for a neighbor when in school. When my turn to pick what equipment I wanted from my grandfather’s estate I took the wide front D17 over the narrow C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 7:33am
If wide fronts are so great why are people paying $10,000 for a NF now?
Guess a lot of people were slow to catch on.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 8:29am
Everybody has an opinion. Like butts, everybody has one. Some folks like the NF Tractors, some don't. No big deal. I think that 6080 looks great, and the owner did a nice job on it. Its different. If you don't like NF's, that's fine, but I wouldn't bash or trash it. Like any other hobby, different upgrades make things interesting. If everybody did the same thing, hobby's or projects would be boring. Be open minded Victory. Different things spark interest and new idea's, and that improves the hobby whether its Cars, Trucks, Tractors, whatever. Not everyone is going to like an upgrade that another has done whether a paint job, engine change, or designing a NF in this case. That's okay. But, there's no need to keep shootin' a dead horse. Word your opinion nicely and move on. This way no toes get stomped on. Pretty simple...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:06am
OK Victory---I throw the towel in!! Everybody get all those narrow front tractors(all colors) out of the sheds and chop,cut them up,melt them down. They were an engineering mistake. Maybe someone can design some sort of kit to use a wide front tractor for the few guys still using a 2 row mounted cornpicker.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 10:48am
Wide fronts, do not make good Tow-line tractors, narrow fronts do.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2018 at 7:42pm
I like it! Yes, because of 'SAFETY' in this country narrow fronts went away. Doesn't mean they aren't still useful or 'neat'.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 12:13pm
i think at the end of the day most people just like the looks of a narrow front tractor, purpose full or not.
dan
JMO
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 3:51pm
I think it looks cool, looks "right". The rest of it, whatever...
Trev
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 5:17pm
Trev
I agree, and the last time I checked I wasn't asked to help pay for it. I would think, the guy can do what he wants with his money.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 9:55pm
mostly around here people dont cultivate three rows at at a time any more witch would be about thirty or forty years now
