200 Injection pump
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Injection pump
    Posted: 18 Apr 2018 at 9:46pm
In a course of a week I have purchased two 200s. This orange bug hits hard when you get it one of them is leaking fuel at the throttle shaft at the pump. It feels like the bushings have play in them and that's what took out the seals? Does anyone know where I can get new bushings and seals or should I just get a reman pump?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 10:54pm
If you have some time, send it to injpump Ed. He will fix it right.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 7:29am
thanks for the plug. If it's just leaking there and runs good, you may buy a little time by trying to replace the 2 orings yourself. The problem is, I don't think the throttle shaft will come out of the pump with the pump on the engine. That should have steel bushings, so orings will likely seal it up. The other problem is, all the other orings are going to be hard and flat too, and will start leaking soon after. Like I said, you can buy some time, but it will not be permanent.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 7:54am
One has to have a short allen wrench and remover the over travel spring assy which is the same on the inside as the outside - the out side is visible as an instruction visual.
The top of the pump will have to be removed after removing the vertical drip line.
There is a "J" clip that holds the outside fuel shaft off shaft to the inside throttle shaft - they join in the middle like a splined pto shaft tractor half and implement half.  (Do not let the J clip fly off into space when it flips off. )   Remove the shafts and replace the o rings and reverse the process.    The super clean sulfur free fuel has little lubrication. We went 35 years with little or no issues - we now do one or two  CAV pumps per month as to replacing seals curing leakages.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 7:59am
Tbran is correct,it can be done on the tractor. It's a little tricky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 2:25pm
Thanks for the replies I have the pump off of the engine. Do I need some special o rings to try to reseal it?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:06am
Curious if you lined up the timing marks before you took the pump off of the engine?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 10:04am
I'm with Ed on this one, If the throttle shaft seals are bad,,, how much longer is the flex ring/governor retainer ring gonna stay together...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 10:57am
Yes I lined the marks up before removing the pump and was wondering if Tbran or Ed was going to GOTO in Tennessee next week and would want build a pump in the parking lot
