WD front wheel hub bolt toeque
vchcv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vchcv Quote  Post ReplyReply Direct Link To This Post Topic: WD front wheel hub bolt toeque
    Posted: 18 Apr 2018 at 9:41pm
Can anyone tell me what the torque is for the front wheel hub bolts?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 5:48am
The ones that hold the rim to the hub?  Its a German requirement.  Goodntight.  I would guess 50-60 ft lbs would be good enough. D17 service manual just had me torque the 1/2" engine mount studs to 70.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote vchcv Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 6:50am
Thank you. I just had two new tires put on the hubs and couldn't find the torque in any of my manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 7:28am
After using the tractor for a few hrs RECHECK THE TORQUE  !!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote vchcv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 10:50am
Thank you. I am "very" new to tractors so any information I can get is greatly appreciated.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 3:42pm
x2! I've had them loosen off before, even after using a long cheater to tighten them the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 8:12pm
I can remember my Dad having front wheels getting loose on our WD loader tractor. He'd by a new rim (because the old one was ruined) and install it. Within a year it was loose and ruined again, all because he never kept re-checking the torque of the bolts as the paint and rust and dirt worked out between the parts that were clamped together. Oil the bolt threads too !!!!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 9:23pm
yes and keep in mind it is the fit of the center pilot to the hub raised cast circle that bears the weight as well. Under heavy load the 5 or 6 bolts have to have the center fit to help bear the load and not fatigue the metal. .
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 2:43pm
Get longer wheel bolts "M.E.Miller Tire has them" and put lock washers and nuts on the back side of the hub.
Best fix I have found for loader tractors wheels that loosen up.
