D-17 Series 1 - Power Director
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series 1 - Power Director
    Posted: 18 Apr 2018 at 2:10pm
The power director will not stay in the forward position without putting pressure on it. It does not snap back to neutral, but just slides back.  There is no problem in the back (low speed) position. Any help is appreciated.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 5:05pm
My Series II slides out of high range occasionally and yet never slips when engaged.
There have been discussions here on this in the past and the cause is generally attributed to worn ramps which no longer hold the rollers in position.
I intend to adjust my clutch to see if that helps but I doubt that it will.
I picked up a couple of complete power  director clutches on e-bay a couple of years ago for very little money. One is in excellent shape including the ramps, so I may wind up changing out the whole unit.
Here is a link to a couple of You-Tube videos showing how to rebuild and adjust the clutch and also explaining what goes wrong with the ramps. After viewing these, you will have a good understanding of just how the PD clutch works. The D-15 and D-17 use basically the same P.D.
The measurements shown in the video are the same for the D-17.
https://www.youtube.com/watch?v=ebbg1YK2I5A
Edited by Brian G. NY - 18 Apr 2018 at 5:10pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 8:49pm
If it is not snapping back, rather sliding back, I would suspect it has to do with the stick itself.  Does the button still have a good spring on it?  If you take the stick off, you will see a block on the back that fits a bracket that is bolted to the inspection cover, check to see if it is worn excessively.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 10:24am
Thanks for the help guys. Actually the lever was loose on the shaft. Tightened it up and I think we're okay. Easy fix this time.Clap
This page was generated in 0.083 seconds.
