B Brakes
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Topic: B Brakes
    Posted: 18 Apr 2018 at 11:01am
My brakes are sticky what's the common reason for that?
Can they be adjusted?
Also how difficult is it to replace the brake band linings?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 11:07am
Sticky?  Probably a lot of accumulated gunk in around the drum and band.  They can be adjusted as there is an adjustment screw on each side down when the actuator rod goes into the hole where the drum is.  It's possible that everything is rusted up.  As for replacing the brake bands:
1951 B
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 11:09am
Sticky in not releasing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 11:10am
Yes. The one pedal does not release all the way back to start position.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 11:21am
The pivot points need a light lubrication. There is a hinge between the two halves of the brake s, it can be lubricated through a hole in the bottom of the axle housing. Check the brake return spring also. Lubricate the pedal pivot pointe.
