Stupid question of the day
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Stupid question of the day
    Posted: 17 Apr 2018 at 12:13pm
The other day I removed the manifold off the D10 to drill and tap the bolt holes that hold the muffler on. Three of the nuts were so rusty they wouldn't come off. The stud came out of the head instead. Two of the holes were the studs were coolant ran out. After removing the manifold, I screwed the studs back in with my fingers and it seemed to stop the coolant, so I figured once everything was back in tight there wouldn't be a problem. I put the manifold back on today and I've coolant seeping out around these two studs. My first question, is this normal, or is my head damaged? I wouldn't have thought those holes went into the water cavity. Second, I need some type of thread sealant to stop the seeping. Is there something I can use that would handle the heat?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 1:23pm
I think it's normal that these go into the water jackets. I put #2 permatex as sealer on mine, but there might be something better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 3:30pm
even thread tape,but you have to tighten them good in the hole.My 45 goes into water also...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 5:25pm
its normal, prolly will stop, once the rust starts workin, again...  If it bothers you, just dip the studs in blue goo, loctite, shellac, thread tape, whatever is handy.  If I were putting new studs in, I'd go with locktite, but that's up to you...
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 6:18pm
I would use something on the threads that MIGHT let them loose next time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 7:39pm
Thanks everyone, I'm glad to hear it's normal. It's probably something a grown man should have already known, but I didn't. I did use some thread tape because that's all I had handy. I knew it would melt, but I thought it might not matter as long as it gummed up the threads. I ran the tractor about an hour afterwards and it seemed to work. I do plan to get new studs later and I will get something better.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 7:42pm
For holes which are open to the water jacket, I use Permatex #2 Form A Gasket non hardening pliable sealant.
Edited by Clay - 18 Apr 2018 at 12:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 9:05pm
Permatex non hardening or Laco pipe dope,or tru blue works best. JMHO
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 9:12pm
Rantz you put the studs back in without taking the nuts off correct
Edited by bradley6874 - 17 Apr 2018 at 9:13pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 12:38am
If you want to remove the nuts, heat them cherry red and then throw cold water on them.  This separates the metals.  Work great when I did it in my D14.  I did overheat a couple too much, but I was planning on using new nuts anyway.
This page was generated in 0.138 seconds.
