New exhaust manifold studs and brass nuts
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: New exhaust manifold studs and brass nuts
    Posted: 13 Apr 2018 at 8:06pm
Hi friends.
Can anyone let me know where to source new replacement exhaust manifold studs and brass nuts for my HD16DC? It's a 16000.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 5:24am
If Minnpar does not have then will have to go generic. Getting a reasonably accurate length on one and looking thru the McMaster Carr catalog is the other option as many small auto parts stores may no longer carry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 5:26am
As far as anyone still educated on Allis parts there is Kwikparts Williamsburg MO, great and well schooled old Allis dealer staff run it.
http://kwikpartsllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 7:42am
Thank you so much for the info DMiller. Great help.
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 9:49am
I put a new set on a HD 21 a while back, purchase them at local caterpillar dealer as they have a large inventory of nuts bolts and studs Etc
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 11:53am
Great Rick. I have s dealer a gal hour away.
Thank you.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 7:53pm
Cat had a hardware catalog they us to call "One Safe Source". Have seen it online when some smart person posts links. Just put it into google and it came up, see if you can find part numbers for what you want. Some of the young help is almost worthless if they have to hunt up stuff. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 7:58pm
Great idea and thank you Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 10:41am
OneSafeSource
This should get you there.
Edited by CTuckerNWIL - 18 Apr 2018 at 10:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 12:30pm
Thank you very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 8:33am
Update on a small item.
My Agco dealer found original in stock exhaust manifold studs. Found 3 of them with brass nuts and washer. $14.00 per stud and I took both he had. This dealer has found me stuff I thought long gone. Staying on their good side for sure.
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 8:35pm
Any of you guys ever use or checkout mcmaster carr? they have the hardware!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 9:13pm
I haven't but will check them out.
Thank you
Corey743 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 4:59am
You could also check with Grainger or mscdirect.com they are both industrial supply companies
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 5:59am
Thank you Corey
This page was generated in 0.107 seconds.
