7060 back to work
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 7060 back to work
    Posted: 12 Apr 2018 at 10:15pm
I've got $4,000 in this 7060, of which, $150 in tool box and tools, $300 in hoses and a power direct rebuild.  Cheap horse-power. It will be on the auger, pump, box blade, ditcher, scraper, brushhog and the disk or field cultivator if one of the other units go down. Cab, glass and ac components would have doubled my input on a $2,500 investment, so I cut the front of the cab off.  I will say it's a hell of a lot easier to dis-mount than the 7020.....
Even with 20.8 radials full of fluid, it will spin out in 3rd low, low side at 1/2 throttle filling the scraper.
So is it worth giving it a paint job this summer? If i run out of things to do, I'll wind up tearing into it.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 12:27am
you dun good Leon!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 7:19am
I kinda like the looks of that.  Will keep the sun off of you and some of the rain.  Different.
And, yes, I'd paint it if you have time.  Just for S & G.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 8:25am
Looks outstanding.  The units I have bought have needed some work too and you are correct you can't beat the dollar per horsepower cost when you do things yourself.  Looks like you do great work.
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 8:37am
Looks TUFF, dont paint it. Much better in there work clothes.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 12:06pm
Leon B MO, your 7060 looks great & like you said a great horsepower value. Is your Soil Mover scraper a 3-4 yard? Your 7060 should have more than enough hp for scraper. I got a similar Soil Mover scraper & love it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 1:54pm
Can't say for sure but I think its a 4 yard, trying to fix some terraces that ran over last year. Ground is just getting dry enough to work but supposed to rain here the next 2 days.
Leon B Mo
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 9:01pm
Looks good. A buffing and waxing would help, cheaper and easier then a tear down and prep for paint.
Nate (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nate (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 4:02pm
turtle wax makes a rough grit rubbing compound in a liquid form.  go over the faded paint with that and then a decent wax afterwards and you wouldn't believe the difference.
*DougW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *DougW Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 8:23pm
For really faded projects, I will use a rubbing compound with the finest steel wool and rub in , wipe off dirt, then use a good cleaner wax. Makes a world of difference.
Edited by *DougW - 16 Apr 2018 at 8:26pm
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 9:06pm
I have plenty of weights when you need them Leon.
