Exhaust Manifold Studs
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust Manifold Studs
    Posted: 12 Apr 2018 at 2:34pm
Hello Everyone.
I had taken off both my muffler on my HD16 to repair and while I was at it, took off the exhaust manifold as well to clean and paid.
Muffler turned out great. While taking off the exhaust manifold, two studs snapped off however I was able to get them both out without damage to the heads.
in replacing the studs are they anything special? They are 1/2" and threaded on both ends of course. Do you need to place any Loctite on the ends going into the block or is that a no no?
BTW I found a small whole worn through on on of the ports but cleaned it up and JB welded it just fine. I found two adjustable bands around this one port and was hoping it was not holding the manifold together. Someone had used the two bands to hold a piece of high temp material over the whole to plug it up. Overall manifold is pretty solid to my relief.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:33pm
If it's been working I don't believe I'd try to fix It. You might take what you have and try to improve on it a bit. Sometimes these little fixes hold up quite well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:27am
Agreed. Just cleaning, all new gaskets, and painting. Treating it gently as these manifolds are impossible to replace.
My son works with s prototype engineering company and are going to scan my manifold and see about milling a new one. Just looking into it but if they do it, might be something to offer this great group.
This page was generated in 0.062 seconds.
