Hd 11 ep transmission issue
Jaberamsey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaberamsey Quote  Post ReplyReply Direct Link To This Post Topic: Hd 11 ep transmission issue
    Posted: 12 Apr 2018 at 11:08am
Hi I just bought a fiat alice hd11 ep. the left hand steering clutch doesn’t work to well you have to stand on the left brake in order for it to turn. Also when pushing a heavy load of dirt with it I. First gear it will slow down to nearly nothing and the driveshaft barely spins. Will changing the hydraulic filters and or transmission filter solve my problem? If so where are they located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaberamsey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 11:12am
I was also wondering since there are two separate fill holes for the hyrdaulics and the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaberamsey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 12:24pm
Also the transmission/ hydraulic fluid is very milky so I want to change it all could you tell me where the drain plug is?
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:41pm
Transmission drain plug is accessible through a square plate on bottom of belly pan, pretty well straight down from the seat.  Bevel gear compartment (separate oil) has three drain plugs, one in the rear center, and then one on each side for steering clutch compartments.  Hydraulic drain plug on HD11Ep is at the front of the tractor...  The screen in the transmission is quite large and there would have to be major problems for it to be clogged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:43pm
Transmission pressure filter is in front of dash on LH side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaberamsey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:59pm
Ok thanks!
do you think changing the fluids will fix my problem with it slowing down to almost a snails pace when pushing a heavy load of dirt without spinning a track? It will spin a track when not warmed up all the way. Is there a torque converter filter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaberamsey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 10:00pm
And filters
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 9:09am
If the driveshaft stops turning, the problem would be in the torque converter..
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 11:11am
You will need to change the  transmission oil if it is milky and clean the trans screen which is easy to get at , use ATF trans oil
This page was generated in 0.173 seconds.
