d10 III hydraulics
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Topic: d10 III hydraulics
    Posted: 11 Apr 2018 at 4:23pm
Anyone have luck replaceing or rebuilding the control valves on a D10 Series III.
The proper 3 point pushes fluid if the engine is running and was capped when I bought it.
1 valve did work, then got super slow, and no isn't working ,but leaking out the back.  The last valve only works if the 1st valve is in the opposite position. Really odd to me.
Need to get the little tractor back to usable.
JIm D
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:01am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 9:04am
Sounds like broken springs and or stuck spools.Might look at if it is farmer plumbed also. HTH Tracy
Edited by Tracy Martin TN - 12 Apr 2018 at 9:04am
