# 1 cylinder position
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: # 1 cylinder position
    Posted: 09 Apr 2018 at 6:08pm
I apologize for what I am sure is a dumb question, but what is the # 1 cylinder in a straight 6 gas engine ? I want to say it is the "hole" closest to the radiator? In the process of a tuneup and we want to throw a timing light on it while we have a "guy" helping. His expertise is I/H and is 99% sure I am correct but I just want to verify. We have an OP manual and an IT brand service manual,so i "assume" between the 2 we should have the timing specs? Any input would be greatly appreciated. Thanks.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:11pm
Correct! #1 is always at the front of the engine.
Now that I think about it...the G Allis tends to trip people up sometimes since the engine is in backward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:11pm
correct on # 1 at least for Amrican gassers
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:27pm
Not all are the one closest to the front. I know the deutz are numbered from flywheel and I think e g is too. Not positive on the g though
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:10pm
In trade school they said cyl  and rotation are no from front of vechiele and all other parts from driver seat .Most  engines are right handed are clock wise  rotation.Boy said that had ditigal watch , what is clockwise!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:07pm
Most air cooled # from fly wheel.      MACK
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:51pm
Timing should be in the op manual. IT manual skips most common stuff and isn't worth the scrap paper its printed on. Look for a real shop manual it will be as much a 200 times as thick. http://www.grandpastractor.com
is a good place to look.
Gerald J.
This page was generated in 0.223 seconds.
