HD11EC help
dclifton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dclifton Quote  Post ReplyReply Direct Link To This Post Topic: HD11EC help
    Posted: 09 Apr 2018 at 2:27pm
Ive got an HD11EC that a buddy was going to borrow. Well against my better judgment he hoped on and i showed him how to run it and let him get the feel for it. Somehow when he shifted gears i think he pulled the clutch in and shifted into a gear about the same time. Anyhow from what i can tell he stuck the gear shift lock in. I have undone the controls that go over to the clutch lever and have ran a bolt through the yoke to see if i could pry on it and pop it out but, no luck.
Have any of you ever had this happen and if so how did you get it out?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 4:14pm
If he shift and pull the cluch in same time maybe the brake cluch is't working  and you should look on right side cluch housing if the rod  shifting lock plunger is't broken and the probleme should be there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dclifton Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 5:19pm
The rod isn’t broke the plunger is stuck in the transmission side under the gear shifter.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 8:32am
If the plunger wont come out it sounds like you need to pull off the shifter housing and see whats hung up
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 1:31pm
I dismantled 5 HD11transmissions for parts some had fork and sliding collar was brooking
and pin  shifting shaft interlook was jam in plate gear shift lock
