7060 bypass filter and oil cooler
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: 7060 bypass filter and oil cooler
    Posted: 09 Apr 2018 at 11:15am
I am wanting to remove the bypass oil filter as recommended by lotsa guru's here,, can the lines to and from the filter be plugged?? or do they need to be looped together?
Next ,, the oil cooler is seeping coolant out of a "weep" hole at the rear of the oil cooler, so far there is no mixing of oil and coolant. I have ordered O-rings and gaskets, looks like this repair is not to complicated,, just like to know if there are any "watch out for" ...
I'll have the cooler tested if I can find some place that will test it...
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 2:13pm
Re: the oil cooler
When you get it apart, make sure you clean all of the cooling tubes completely. It always surprises me how much stuff gets plugged into those things.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 3:46pm
Spin on bypass filter? I'd buy it from you if it is.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 4:31pm
Nope,, its the big cartridge type,, if it was a spin on I'd keep it and not worry about it.. I would like to find a spin on type to put in this ones place, but its going to go away..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:16pm
When you press cooler out of housing, be real careful not to bend edges where o rings seal.
Put the correct oring in the correct location. Two are for violent, two are for oil.      MACK
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:51pm
For the spin-on by-pass filter base I used a fleetguard base that accepts the LF777 filter. I installed it were the luberfiner was previously located. When I bought my 7080 someone had removed the luberfiner housing. I used 1/4 hyd. hose and fittings for the plumbing. Make sure though you use the restrictor orifice that comes off the oil cooler. I use a Donaldson P55777 filter on mine. Our two 7060's still have the luberfiners and are changed every other oil change. Both have earned their pay and have an easy life now. Good Luck, Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 6:53pm
I got a base ordered for the spin-on type bypass filter,, I will update with a part number when I get it tomorrow.. now I will still have extra oil capacity and cooling effect from the extra filter...
AGCO parts shows the restrictor orfice is in the inlet of the luberfiner filter case, also shows check valves in the in and out lines,,, do I need to keep the check valves in the system also??
the black circled hole is where its leaking coolant..
any special lube on the O-rings??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:00pm
for Peterson and others that may want to know, the base for a spin-on bypass filter is WIX 24750, a good parts store that carries parts for the bigger trucks should be able to get ya one,,, shoot,,, may be available 'online',,, I haven't checked.. mine was about $65.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:39pm
The weep hole is normal. All of the 426 engine coolers have one. It just lets you know when you need new o-rings.
I have seen some guys braze or weld them shut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 10:09pm
can't fix stupid!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 10:57pm
I figured that weep hole is supposed to be there,, jus like the ones on water pumps and the early 4020 JD's,..to let ya know that the o-rings are failing/worn out....heard of people doing the same thing on the deere's...plugging, welding, etc...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 2:33pm
The hole is to let pressure out and not try to compromise the other o-ring
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 2:50pm
Filter base from Amazon is $49.95-anybody know what the filter number would be?
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 5:53pm
I used the filter numbers that Mike Kroupa gave in post above and ordered a base that fit those filters..LF777, P55777, I got a Baldwin B7577, cause that's what the parts store I use carries
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 5:55pm
The WIX number is 51749,fleetguard LF777, Donaldson P550777, plus many more.
