Twin turbo
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: Twin turbo
    Posted: 08 Apr 2018 at 8:29am
Has anyone run twin turbo set up on the 301 here. If so turbo size were used?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 9:47am
What size do your rules allow ??  How much fuel delivery do you have ??  are RPM's open or limited ??   We used to run a TV77 on top of a 3LM466 with about 400 cc's of fuel with open RPM's many years ago. Worked quite well and I suppose the HP was in the 600 to 700 ish range  ??  Now we must run a max of 3 inch air inlet and the fuel is double and the HP is around 1200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 11:12am
I think im switching div. Rules are pretty open. I still running roosa ed did i believe 400cc going bump rpm up was thinking 35 3800
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 1:04pm
When we first went to twins, we had been running 7th gear in the 6700 lb class with a 190/200 chassis. Adding the TV77 (or an S-3) on top of the 3LM466 allowed us to shift up into 8th gear.  This was with 24.5 x 32 tires and open RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 2:28pm
Were able to keep it all under hood with out notice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 4:37pm
That is a question???   No bubble in the hood, but inlet and exhaust went out thru the hood sides. If you are trying to hide twin turbos so no one knows you have them, good luck with that idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 5:51pm
Thank u for info dr
