B front main seal off BUT
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Topic: B front main seal off BUT
    Posted: 07 Apr 2018 at 6:21pm
The seal had been replaced once it looks like so no clue why the modern seal failed... why is the shaft not smooth???
On a plus the pulle came off 8n my hand LOL
Edited by archangel_cpj - 07 Apr 2018 at 6:22pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 6:35pm
From the factory these tractors had a seal that I believe was several thin pieces of cork sandwiched together, at least that's what mine was. The cork kinda just slows the leak rather than completely seal it, so the spiral you see is meant to push the oil back into the motor when it's running. That will not work with a new modern rubber lip seal.
My B was an earlier model and used a smaller diameter seal, so I used a Dremel tool to bore the hole out a bit bigger for a modern seal. What I did to fix the groove was make it all nice and clean, fill it with JB weld, let it cure, then file/sand it down until it was smooth. Allis B/C/CA expert Dick Lemmons here on the forum advised me that, and while I was doubtful at first, it worked great and has been leak-free for almost 2 years. Since the seal rides on the metal crankshaft, it won't wear down the JB Weld.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 7:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 8:35pm
wire brush all the paint off... and sand the surface with sand paper then wipe off with acetone prior to installing the JB weld into the groove.. then sand down smooth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 8:39pm
Also, if you'll take a small pick and clean out the groove that way, it will help remove anything the acetone doesn't get out. After 70 years, there could be some stuck-in stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 9:28pm
THANKS my dad is in fiberglass so acetone is easy..   I thought that was the groove but wanted to make sure.. I can't believe that pulley came right off...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 12:13am
You might check your crankshaft key and make sure it is alright, or even go ahead and replace it anyway. Mine came off really easily as well. Turned out my half-moon key was shot. It was so worn, that if it went much longer it would probably have sheared the rest of the way off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:42am
Yep its shot gonna add a new one any idea on size or do I wing it
