Fork lift Won't start
Rod View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Quote  Post ReplyReply Direct Link To This Post Topic: Fork lift Won't start
    Posted: 06 Apr 2018 at 10:08am
Hi, We have an Allis Chalmers Moderl No: Acc40C PS Type G
It was running good for years of normal use, one day It just didn't start!!! I checked
all ignition system and found no problems on it, the propane seems to be the issue
to work on, but not sure if the gas valve is blocking the gas or something else. At this point, it's been a few days of trying to fix the problem with no success! If some one can help me with this problem, It will be  appreciated and any suggestion on what can I check next, please let me know...Cry
WDman1949 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDman1949 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 4:32pm
Rod check your PM as I sent some help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 6:53pm
When they sit, the hole spiders plug up the propane regulator valve...
