8070 670I engine
electroman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote electroman Quote  Post ReplyReply Direct Link To This Post Topic: 8070 670I engine
    Posted: 04 Apr 2018 at 2:40pm
Shop manual says there is an antifreeze drain cock on the right side of engine. I cannot find it. Is it behind the fuel filter?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 3:08pm
Is there a tank heater installed in that spot?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote electroman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 5:14pm
Tank heater installed on the cooling water inlet of the oil cooler
MN_M2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MN_M2 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 6:51pm
There is a drain plug on the bottom of that water inlet to the oil cooler, with the tank heater in it.  The block drain I think is on the left side under the air conditioner compressor, if it has the cooling system conditioner its on the lower line at the end where it goes into the block, kind of hard to get at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote electroman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 5:33pm
thanks will look for it.
