Ftpl 30-24 forklift info needed
Corey743 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Topic: Ftpl 30-24 forklift info needed
    Posted: 04 Apr 2018 at 10:16am
Can anyone help me with the weight of a ftpl 30-24 (that is what the tag had on it for the model) forklift. What years where they produce and can you still get parts for them. What would it be worth it is in non running condition right now. Thank you in advance for any information.
Fixindude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fixindude Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 9:06am
Hey, am new here got a FTB30-24........great little lift, have a parts manual and am lookin for a service manual, send me a PM with any questions and we can talk rather than TYPE!!
Go Pens!!Wink
TOM H View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 1:33am
I also just got a FTB30-24 LP serial #51579. Has a 133 CI Waukesha LP 4 cyl . This one has a side shift option . I needed a few parts and found everything at Tru-Par.
Allis-Chalmers 1927 E,1928 U,1944 WC,H3,D10,D12,D14,D15,D17,D21,TT-10 Terra Tiger, 1964
AC Golf Cart, Allis Chalmers Fridges,100's of AC Literature and Ops.and Parts manuals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 7:00pm
Thanks Tom for the help with the lead on parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 5:52am
I just purchased the ftp 30-24 over the weekend. I'm excited to get working on it and getting it running. I am not familiar with LPG fuel system so can anyone help me with identifying some components. There is something leaking when I turn the gas on, it is the first thing the line goes to and it almost looks like a filter canister but it has what looks like a solenoid attached to the line coming out of it. If anybody could give me some information on what that is I would really appreciate it
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 9:51am
I will take a look in the parts book and see the options.  I know my book shows 3 different brand LP regulator brands.  2 of them are Century and Ensign. The item you mentioned is the fuel lock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 9:39pm
OK. I see ENSIGN, ZENITH, AND CENTURY LP GAS SYSTEMS. Need to know which you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 6:19am
It is an ensign filter housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM H Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2018 at 9:36am
My parts book is for FTL20-24, FTL25-24, FTBL30-24  LP Lift trucks  which I believe are newer than yours. My Model FTB30-24 has a Waukeshau 4 cyl motor. Not sure if the LP system parts are the same.  The Ensign regulator has fuel lock mounted to it. if it is the same. The solenoid # is 74055623. Repair kit is #74055065
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 4:46am
Tom I wasn't able to open the link that you added to you last post. The system on my forklift has an ensign filter housing and the lock off is right after the filter do you know know who made the lock off. It also has a safety pressure release valve close to the lock off and I think that is my problem. That is what is leaking. Thank you for all the information
parf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 3:43pm
Hello,  We purchased a used Allis Chalmers FTB 30-24  Forklift and are trying to find parts for it.  Unfortunately, it didn't come with a manual. Does anybody know which brakes are needed for it.  It's an old unit and we've done servicing on it to get it running.  Now need to replace brakes and are having issues finding the correct size brake shoes and brake kits for it.  Seems that all attempts for brakes are much smaller than the unit requires.  Thanks in advance and any help is greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 4:23pm
I took my shoes to a local shop and they relined them, 1 day service !
parf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 4:29pm
Thanks so much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Corey743 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 5:50am
You could try Hgmforkliftpart.com or trupar if you havent already done so. There are a few other posts on here that refer to these lifts. Some of the people that posted have parts or maintenance manuals. There is also a guy that restored a ftb 30-24 that may be able to help you I'll try to find the exact posts for you
skyboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 7:02am
Tom, I am working on a FTB 30-24, I have a factory parts book I'm happy to share imfo with, my question is a FTB 30-24 the same as a ACC -40-ps or a ACP 40-PS ? Or do you know the military identifier for same? I need a service/maint manual.
I'm asking because I found a "liberated manual" here https://www.liberatedmanuals.com/TM-10-3930-644-14-and-P.pdf
I have 2 issues, I 'm afraid to download it fearing malware and I'm not sure this is the correct model
 "Alice" my old lift began running rough after a coolant leak got the dist wet. The wires were so old they broke off when I tried to remove them!!
 So I put on a new cap, rotor, wires and plugs...........she still barley runs.......this am I will go out and warm the LP regulator and see if it smooths out?  If not I will install the new points and ops check it again. Any help would be appreciated I wrote you after seeing you had a lot of AC literature!
 Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 7:43am
I've downloaded several manuals from liberated...no malware.....just did the one in the link.... it's 717 pages long !
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 1:08pm
Thanks, I had bookmarked but will download! Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 1:10pm
Is a FTB 30-24 the same as a ACC -40-ps or a ACP 40-PS ?  Thanks.
SmokinJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokinJoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2023 at 5:39am
I just bought a FT30-15 for my hardware store and I am having a lot of trouble locating some.  I keep finding the F30 and the FTB30 and sometimes the FTP30.  Do you know if they are just different generations and which ones would be close enough for a manual?
My forklift still has the Buda name embossed on the gas tank cover and the hydraulic control cover.  So, I assume it's relatively close to when Allis purchased Buda.
v/r
Joe
This page was generated in 0.246 seconds.
