Engine Valves
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Topic: Engine Valves
    Posted: 03 Apr 2018 at 3:52pm
How can you check if a valve or valves is stuck? I think some water got in the engine and some are now stuck. The engine is free now and I had new valves and springs installed prior to my roof leaking on my B.
What is the best way to free any stuck valves?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 4:36pm
Remove the valve cover and push or pry each valve down and see that they come back up. Those that do not come up oil the stem and work the valve up and down until they move freely. If they were stuck in the full up position you would have a bent push rod to that valve.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 4:47pm
Compression test.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 10:21pm
Dick has best answer so far...
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 8:08pm
Thanks guys. I used a clamp on each valve. They all compress down and back up again!
They seem a little difficult to compress though but maybe valves are supposed to have that much tension? Not sure?
I sprayed the head and engine down with Fogging Oil and sea foam as well sand let it sit for a day.
