G experts
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: G experts
    Posted: 01 Apr 2018 at 6:50pm
I am having trouble finding what was used to shift the pulley in over the lh rear axle. I see what is used for the hyd lever but haven't found that linkage. Also what were the options for the PTO's / belt pulley. We have two in the shop and one has a shifter, the other not.. both have belly mowers which is awkward on the non shifter unit...
Edited by tbran - 01 Apr 2018 at 6:51pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 6:57pm
Wow, a belly mower you can't shut off? That would be awkward. Personally I've never seen one with a shifter, so I'm not much help.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 7:15pm
Main pulley always runs. I have an idler pulley on mine that turns the deck off and on.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 7:35pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 10:06pm
If I remember right, if the G has hydraulic then it has a lever to shift the pulley and hydraulic in and out of gear to gather.
Dusty
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 4:38am
Right on Dusty.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:01am
OK, If I have this correct, the belt pulley runs all the time, unless there is a hyd option which in this case there is a shifter, but no linkage to the shifter, just the hyd cyl actuator..
This unit predated OSHA , ha...     Oh and I found out a safety feature, the clutch lock down washer.  This prevents an old man from finding out how fast he can run when he stands beside the unit,  pulls the switch on and then the starter rod and the unit was accidently knocked in gear.
The low weight prevents any broken bones when the unit runs over the left foot...   :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 11:28am
I built a linkage for my G.
I accidentally kicked the transmission into gear while climbing on from the left side of mine. The rear wheel climbed up the side of my foot. I grabbed the wheel and stalled the engine. Had a sore ankle for a few days.
Dusty
This page was generated in 0.293 seconds.
